My machine uses 140/90-16 in the rear. What is the deal with using smaller ones, like 120/90-16? I thought the 120-140 number was the number of degrees of tread on the face, but now I don't know...
On a number like yours it goes Section width/aspect ratio - rim diameter
So your section with is 140
aspect Ratio is 90
And your rim diameter is 16
IOW, if you cut the tire in two, you would see it forms an oval shape that is 140mm wide by .9*140 or 126mm high when mounted on the correct width rim.
Its been my experience to use the original size tires or you might have an issue:
Your tire is 140 mm wide, 90% (126mm)as tall as it is wide on a 16" rim. By going to a 120/90 your tire is narrower (120mm) and shorter (108mm) than the original which will affect handling, suspension, and the overall geometry of the components.
