Hey guys, I'll cut to the chase! I own a gixxer 750w 1994 and here in the country (Brazil) I have difficulty finding some parts of the carburetor in case the float .... looking over the internet I saw that the 1100w float and some 750f versions the float It is similar ... that in the case here I find easy ... I would like to check if anyone here already used any float of these other models at least temporarily until import from Japan .. tks.
my toy!
60318
I have not used the different floats but the part numbers are different. (Both 1994-w)
Although with Suzuki that might not mean to much... ? Sorry, that's all I got.
Is there some reason you can't use your current float? Damaged to point it's unusable or does it have a hole? If a hole you might be able to put a very thin coat of epoxy over the hole as a temporary fix. I just can't imagine how one could get damaged beyond use unless some animal removed it. Maybe bite the bullet and purchase a new carb???
