O
OldGuy
·Guest
I changed the oil today and noted a gasoline smell in the old oil.
Is this possible, if yes what would be the cause, (head gasket?)
It sounds like you have some carb work in your future. In addition to being dirty and gummed up, the float valve is probably sticking open, allowing them to flood leak fuel into the cylinders and then down into the engine lower end. It's not terribly good for the bike, so you should probably look into it ASAP.Thanks for the response. 2005 Hyosung GV250 (POS!) 8,725 miles.
Also, it smokes when I first start it but goes away after a couple of
miles. I should mention I believe the carbs are gummed up so I
have to run it with half choke. It sat for a while before I bought it.
Gasoline acts as a solvent, not an additive.Gasoline thins out the oil. So if you have 10W40 in it, it'll more act like 5W30, or less, depending on the quantity of gasoline in the oil.
It's also in danger of exploding, if the gasoline levels get too high.
But a little can do no harm. Just add some very thick diesel oil, like 15W50 or more, and pour a little in the engine, to thicken the overall mixture.
Back in the days, on a cold winter day below freezing, in order to get oil flowing through the engine, sometimes truck drivers would pour some kerosine in the oil, to thin it out.
Most of it will burn off as you ride.
The rest gets mixed with the oil, and acts like a thinning agent (much the opposite of the additives in synthetic oils).
Yes, you did. That's exactly my point, it doesn't do the "opposite". That's like saying someone should just eat some healthy food as a cure for ingesting poison, because eating something good for you is the opposite.Didn't I say it works the opposite of the additives in oil?
Gasoline does indeed break down oil and make it ineffective. There's not a lot of information out there on mixing the two because it's a really, really bad idea to do that.There's not too much info out there on gas-oil mixtures, but my comprehension of it is that gasoline does not break down oil.
Otherwise, it would be useless in 2 stroke engines, to add oil.
It merely thins it out.
face palm 3.
Two stroke engines are designed differently than four stroke engines. They don't hold oil in their crankcases like a four-stroke does. We are talking apples and oranges here.I don't know, you tell me...
If gasoline breaks down oil, then two strokers are running dry...
Makes no sense.
Don't do this, replace the oil.Gasoline thins out the oil. So if you have 10W40 in it, it'll more act like 5W30, or less, depending on the quantity of gasoline in the oil.
