1 - 2 of 2 Posts
OEM has discontinued supplying fuel pumps for 1986 Honda Shadow 750.
I am sure that something else will work.
Does anybody know of a pump with similar specs for volume and pressure?
Rewiring a plug is not an issue if everything else is the same.
I had a problem with my pump, what the problem was the line was backup with old gas. I had to flush out the pump using gas hand pump I used gas distabliser to clean it, once I had the distabliser in the pump I let it sit for 1/2 hour the pumped gas in. The fuel pump started to work fine. Make sour you get gas into the pump and that it clean out of old gas, there sight call CheapCycleParts.com/Honda it has the pressure table for my Honda look them up.
1 - 2 of 2 Posts
