I have a 1990 PC800 that I have been working on myself. I have had an issue with the ride since the beginning. I bought the bike with an out of round tire which I replaced because it caused the front end to jiggle up and down. Further, it had bent forks and so there was severe binding, which likely contributed to the tire's out of round wear pattern. I replaced the forks with used ones that I rebuilt using All Balls bushings and seals and Maxima 10W fork oil. They work reasonably well but have about 15mm of stiction which I have tried to address by polishing the tubes using chrome polish and a towel. I verified the straightness of the tubes on a glass table and have reset the alignment many times using different methods. The up and down jiggle persists, but only shows up on smooth pavement when the bike hits a dip or a ripple in the otherwise smooth surface. This bobbing goes away when the wheel encounters a real bump, and also does not show up above about 45 mph. The frequency of the jiggle is independent of speed and seems to be about 5 to 10 Hz, as if the tire and bike are acting as an undamped spring and mass system excited at its natural frequency. It usually only continues for a second or two, but can maintain continuous oscillation on a very smooth road between 20 and 35 mph.
I turned my attention to the tire and wanted to check if it had balance, out of round or out of true issues. It has maybe half a millimeter of out of round and perhaps 1-2mm out of true. The wheel itself is very close to perfect. I checked this by inserting the axle into the wheel and supporting it with jack stands then using a vice and a small rod as a makeshift indicator. The balance seemed perfect while it was on this stand because it had no tendency to rotate at any angle. It is inflated to 38 psi to accommodate the weight of the bike and the rider's 230 lb mass. Still the jiggle persists.
I noticed a bit of play at the ends of the forks with the wheel lifted, and because of the bike's age I decided to upgrade the steering bearings. I installed All Balls tapered roller bearings and dialed in the correct preload through trial and error. I hoped this would stop the jiggle finally, but it is still there.
If I grease the forks, stiction reduces temporarily to a more acceptable figure of about 5 to 10mm, and the jiggling is less pronounced. However, with stiction in this range I would not expect appreciable issues with the ride, and fork travel feels smooth and reverses without a hitch. My guess is that the forks are better able to absorb the jiggling which mutes it somewhat.
My question is this: is there any other conceivable mechanical issue that I can eliminate before trying to replace the tire which has less than 1500 miles on it? I have been on a PC800-specific Facebook group and discussed it with them and eventually the consensus pointed toward the tire being the culprit, but after all I have invested, getting a new tire and still having this jiggle might put me over the edge. :wink2: Any words of wisdom are appreciated.
