Still air in the system, probably in the banjo fitting at the master cylinder. Try moving the MC reservoir so the fitting is below the cylinder a bit, then slowly squeeze the lever until tight, or against the grip, hold several seconds, then let it snap back. This should pull a bubble into the MC, where it can be expelled into the reservoir by gently moving the lever in and out, then start again.
