1 - 20 of 24 Posts
So we all hit stuck bolts every once in awhile. I've used loctite, a hammer, cutting them off, and just about everything else I can think of... but I figured I'd see if there's any better tools out there for pulling apart stuck bolts like the ones in the images below:
http://i.imgur.com/hy4qCAp.jpg
I so rounded that off, but I don't have a dremel to just cut it apart (before I'd use a hack saw).
Are there any tools/tips/tricks out there I should look at?
Sometimes you can put a super amount of force when squeezing a pair of Vise Grips closed to lock on. I've twisted bolts in two doing that. If the Vice Grips have good sharp ridges it works best. And if that doesn't work then hack saw or Dremel cut off wheel.
these worked for me http://www.harborfreight.com/media/...b33525d08d6e5fb8d27136e95/i/m/image_14203.jpg The item number is 67894 [metric bolt extractor sockets]
Another thing you could try is to use a cutting wheel to cut the end from the socket that fits the bolt. Some of the sockets have a fairly deep eased end that really does not allow the socket to fully grip the bolt. If the bolt head is somewhat shallow, it rounds off
Although I am usually not a fan of cheap tools, for things like cutoff wheels, vice grips, hacksaws it's hard to beat Harbor Freight.
Closest one to you is
5054 DORCHESTER RD.
N CHARLESTON,SC 29418
Pb Blaster, a good set of vice grips, and a hand help torch.
Try to use a screw driver and a hammer.. place the phillips on the edge and use an angle where the screw driver doesn't just slip away and just keep hammering it
I agree with dodds if cutting it is not an option. Pb blaster and vice grips mixed with a little elbow grease usually does the trick. However I have used sockets like the ones mentioned above and own a few sets of them. They work really well.
Master of Rex Kwon Do
A cold chisel would work better than a screwdriver. For a 20-cent nut and bolt, I would just cut the thing apart, though.
I've also used an air chisel like this^^^.
Sorry...New to the forum and need 3 posts before I can post any new threads to ask more pressing issues...
Grinder, cut off wheel,chisel,vise grips, and so on,I guess would be pretty standard remedies for your 9 to 5 nut and bolt.But what could be recommended
for bolts in a blind thread,like exhaust manifolds and sorts?Other than break,
drill, and extract/ re-thread.I'm pretty good at the latter,but would rather not be ;).
They make a special tool for this..
called a nut splitter.
I used to have one, I haven't used one since I found WD-40!
soak it overnight with WD-40(or knockerloose), Then work it.. back and forth with two vice grips until it frees, or breaks... either one.
A cold chisel is one that is meant to work on cold metals, as opposed to a hot chisel which are designed to work on metals hot out of a forge. It's an old blacksmithing term.
I've never heard of a cole chisel.
I'd like to see where you got the Cole name. I might(but I doubt it) learn something.
I'd use what's affectionately referred to around here as the "Wheel of Death."
The "WoD" makes problems go away. Rapidly.
Yep, that wheel of death gets alot of use at Joe's garage. There's a new product out now called "Freeze Off" it works better than PB Blaster. Both products are good but Freeze off seems to work better.
When all else fails, Joe grabs the torches....that's when you know its bad....
Is that a ground wire connector? If you really have problems, you can put a new connector at the end of the wire and just cut wire right below the connector and toss nut and connector too....
1 - 20 of 24 Posts
