Straight forward question can you weld floating disc to make it fixed? Reason they seem to fail on the connection between the 2 parts and still have a lot of wear left in the disc
Wouldn't that change the temper(hardness) of the metal?Straight forward question can you weld floating disc to make it fixed? Reason they seem to fail on the connection between the 2 parts and still have a lot of wear left in the disc
No.Straight forward question can you weld floating disc to make it fixed? Reason they seem to fail on the connection between the 2 parts and still have a lot of wear left in the disc
Red Loctite is not to be used on Anything that might Ever need to be removed. It is considered to be a non-removable, permanent thread locker.Got some second hand. Anyone have a workshop manual, not sure if they used the heat red locktight like on more modern triumphs.
