Hi everyone, so here is an update to my bike. Friday night I had the battery tested again at advance auto and this time, he found the battery needed to be replaced. So I got a new battery, filled with acid and charged it properly according to the manual. The next day before installing the new battery, I tested the voltage and read around 12.78.
The motor turned much stronger than before but it still couldn't fire up. So I decided to give the air box a spray of starting fluid and got it fired right up, I kept it running for a few mins before shut it off to see if it'll crank back up and It did!
I kept it running for another half an hour, the idling sounds fine although it has a weird whining noise? It sounds to be coming from the motor or transmission, perhaps a worn out gear or a pulley? I'm not sure if motorcycle uses pulley and belts like a car does, I've also checked the voltage on the new battery multiple times during this. After both the start up, the voltage was reading around an avg 14.3 during idle and drops back down to around 12.7 after powering off. So I can't say for sure if the previous owner was right about the charging issue on the bike, until I figure out how to conduct a continuity test on the stater. Then the next morning I tried starting the bike up again, the battery was reading at 12.78v and the bike turned a few but the same problem happened again. It turned very weak for a few and stopped, nothing happen again just like it did before with nothing but a "click" sound after releasing the start button. I tried giving another spray of the starting fluid but with no luck, I tested the battery again. It read an avg of 12.08 with the key on on position and a avg of 12.6v with the key off and it'll slowly raises back up to 12.7+. I gave the bike and the battery a few hrs to rest before giving it another shot with the battery now at 12.78v but again no sauce. I am very lost at this point but I can rest assured that the motor is still alive and healthy, I also went online to print out the service manual. I would also like to know if anyone knows why on my initial inspection, I found a hose coming off the bottom left side of the bike leaking out coolant (green fluid) I suppose? I've heard some say is normal and some say its not, I can only find 2 image from the book so far that seems to possibly showing the same hose? One does not indicate the name of the part and the other is a crankcase breather? Could this be a ac drain hose, there's also seen to be another hose beside it that I now notice after taking a closer pic. I did also notice another hose on the right side of the bike during my initial inspection as well but it seems to have no leak of any kind and it seems to be coming off from the carburetor? (I do not have an imagine of this atm)
F.Y.I I am no skilled mechanic, I only know very little about cars. Only had done routine maintenance, changing out small parts, brakes and calipers before. I do not hope or rush to get the bike on the road any time soon, I drive a stick shift but has never driven a motorcycle nor has a license to. I purchased this bike from a elderly gentlemen for $550 with the sole intention of learning, passion and experience, I had always dream to own a motorcycle and a project to work on. Which is still my civic but this bike will be my winter project and a valuable learning experience! I appreciate everyone that has been supporting me and I will keep this posted! ?
