· Registered
I just got a 1981 honda cb650 the last owner said it needs atleast new heads but i got a fresh battery and brought it over and she fired right up so id really just like absolutely and tips and suggestions on what else i should do before i put her on the road
· Registered
i wonder why the previous owner said it needs new heads.
you say it runs ... does it run WELL ? I.E. idles well without the choke once it's had a chance to warm up, responds smoothly to the throttle. if not, it will need a carb cleaning.
· Save them all!
Welcome! And welcome to the world of old bikes!
Congrats on getting it started. Get yourself a repair manual for the bike and give it a good tune up, valve clearance, etc. Make sure the service is up to date and then see how it goes.
Any oil leaks or smoke from the exhaust? 0
· Registered
Discussion Starter · #5 ·
i believe there is an oil leak while running not so sure where from yet but no smoke no and that will defietely be doing a tune up just really want to do a real thurough re up so looking for guidence on everything to do
· Registered
What cmonSTART said...give it a good tune up and go through the bike, check the brakes, cables, dumb stuff like making sure the petcock doesn't leak and whatnot. I would also run some Seafoam through a few tanks of gas just because.
