I have a 2003 Suzuki Intruder 1500 and the thing was running and starting fine. I went out one night to ride to work and it cranked over two or three times and acted like it was going to start and lost complete power to everything. I checked all the fuses and relays and even the ignition switch. Can't figure it out any suggestions would help.
If you've got less than 12.5 at the battery unhook it and charge it.
After that, I'd check your battery terminals and main ground for corrosion/looseness.
