Yesterday, i found a broken off bolt that held the points eccentric [the out of round piece that opens and closes the points] It is part #7 in the drawing
http://www.hondapowersportsoftroy.c...=Motorcycles&make=Honda&year=1974&fveh=133054
Worst of all, it broke off about an eighth inch inside of the threaded camshaft end!
I needed to drill a perfectly centered hole in that broken bolt to avoid buying a new camshaft. The bolt in question is only 6mm diameter or about 1/4 inch. I made a drill centering jig by finding a tiny socket that was about 6mm outside diameter. I chucked it in my drill and rotated it into a mini-grinder to reduce the OD just enough to fit into the recess. The inside of the socket had about a 3/32nd hole through the center which I used to center the drill bit and keep it from skating across the irregular broken surface. Once the drill bit marked the surface, a center punch was used for good measure. I drilled the small hole deeper and then a bigger one to accommodate the screw extractor.
It worked like a charm. The broken bolt came right out with the camshaft female threads intact.
