Hello All,
I purchased a 2008 DR650SE last winter. After some adjustments it runs great, but I recently got around to installing turn signals, and they won't flash. When I attempt the signal, the corresponding bulbs remain lit until I cancel the signal. The signals are standard, not LED, the flasher is the OEM unit as far as I can tell.
Based on my online research, it is either:
A.) Flasher relay is bad, and must be replaced
-or-
B.) Insufficient load to trigger the flasher relay, caused by a poor connection or wire (or use of LED signals, but mine are not LEDs).
I have NOT been able to determine, though, what readings I should see at the relay to determine if it's still good. I'd rather not replace the flasher relay if it's still good, or spend hours chasing a short if the relay is bad. Does anyone know what the proper readings are to indicate a good or bad flasher relay?
Thanks,
Patrick
-or-
Thanks,
Patrick
