1 - 10 of 10 Posts
Found the power line that goes to the relay that I think has the diode in it.
I used the diode test function on the meter, and it came back dead one way, 1616 or 1615 the other way. I suppose this means the diode is working.
tell me... what does 1616 mean??:mad:
I am getting 10 volts instead of the full battery power to the RR, and it is the same amount at the alternator. I don't know if this is right or not.
Relay? Or rectifier?
By dead, do you mean open circuit, as though you weren't touching it with the probes? If yes, that, combined with the 1616 reading indicates a working rectifiier. What 1616 means depends on your meter; on mine, it means there are two diodes in series, or a resistance in series with a diode. Do you have a link to your schematic, so I may give a better answer?
Not sure where this measurement is taken. Is the key on, engine off? A schematic would help a lot here, too.
diodes, are like gateways that are open only one way, and closed the other.
they keep current in a line while a device uses it, rahter than draining it to ground. It is used in low power situations where the power must be constant for the device to deliver a proper reading, like an electronic tach.
They are also used in rectifier circuits to keep the power flowing in one direction only.
Son, I've worked with diodes since 1967, so I know fully well how they work, and how various meters give different readings of them. Also, there are more kinds of diodes, used for different functions, than you mentioned.
K sorry.
The wiring paper I got for it, does not have 2 relays on it, my bike has 2 relays. the first one I think is suposed to power on the instrument panel, and the other I think is supposed to power on the starting relay from the kill switch.
I think they are supposed to be different. I took the old ones apart to see if there is a difference, and one switches the diode in a different direction. because there is no diagram to look at, I can't tell which goes where.
there is a 3h5 omcron and 4h7 omcron 1981 XS1100 yamaha. anybody know?
two diodes...
If there is an inline diode, and a diode in the relay that would account for the 1616 reading huh...
So why does the field need a resistance of 3.5 in it? and why does a stator need a resistance of .4 in it?
The field is a coil of fine wire, consisting of many turns; the total length of the wire creates the resistance. Same is true for the stator, but it is wound with a thicker wire, with lower resistance per foot. If your meter is accurate at low resistance, a lower than expected resistance indicates the insulation on the wires is damaged, causing shorts and effectively reducing the length of the wire.
Very few meters can accurately read less than 1 Ohm, and many inexpensive ones have issues with less than 10 Ohms. The meter I use was $140 new, and was made by Fluke.
Discussion Starter #9
What would melt my inline diode?
Like I needed to know that the field coil was exciting the stator, and it does when I apply 12v, but it melted my inline diode. I know jack about inline diodes.
1 - 10 of 10 Posts
