We have a daelim daystar 125 and when driving home recently it completely cut out, no fuel is going in and no spark, started with the spark plug, then replaced coil and no luck. I guess it would be the ecu? There are 2 for sale on ebay, one has a very similar code on it to mine but states it is for a daelim roadwin 125, would it fit the daelim daystar 125? The one that's advertised as for the daystar has a very different code on. Has anyone experienced a similar problem? Any help or advice appreciated, thank you in advance
Before you start swapping anymore parts, are you sure you didn't blow a fuse, like a main fuse somewhere.? This just sounds more like a fuse problem than a ECU problem. But have you confirmed all the fuses are good?
Have a Daelim Daystar 125cc which has been left in garage for 3 years. Unfortunately there was fuel left in the tank. what is the best way to drain the fuel out of tank. Turned fuel cock to off then put a drainage hose to the outlet turned the fuel cock to on but no fuel came out?
