· Registered
So I got this Cylinder in this condition. As you can see there’s a big chunk that broke off. Is this still okay to use or junk? Also what is the best way to clean this up? Thank you!
· Save them all!
The broken fin really doesn't concern me all that much - fins break all the time.
The cylinder walls are going to need a loooot of machine work and clean up though..
· Gone.
It might be okay-ish wthout the part of the cooling fin but I'm more concerned with the bore. If it has any pitting at all it will have to be bored out and re-finished, and that bore looks pretty nasty. If it is a hard material you may be able to remove the rust and refinish it, but you're going to have to measure it to make sure it's within the service wear limits and isn't belled out or misshapen somehow.
· Save them all!
Well there it is.. Eye I wrote that post this morning but it never showed up. I guess it appeared sometime later..
