I am a motorcycle newbie; I got my license and Ninja 250 in July. On top of that, I am a total newbie when it comes to anything mechanical. I do plan on learning and my goal is to eventually learn how to fix my own bike, but right now I'm having one minor problem:
I don't know what choke is and why it is/isn't good/bad.
I have been having a problem with stalling at the first couple of stoplights when I first start riding. I've been told that I'm using too much/not enough choke.
Here's what I do when I first try to start the bike:
1. Try to start the bike without using any choke.
2. If it doesn't start, I bring the choke lever to the halfway point (where the choke actually starts) and start the bike.
3. I will keep the RPM's below 2k while it's warming up and take off after about 2 minutes.
4. Bike will usually stall at first stop light.
5. Open choke a little more and start bike up. I close the choke at the next stop light, which is about 7 blocks from my apartment.
My manual says that I should turn the choke lever all the way up (but this sends the RPM's screaming!) if it's a cold day and to keep it under 2.5k RPM. It also says to continue to back off the choke until the bike can idle on it's own and to not let the bike warm up for more than 5 minutes. But this doesn't really help either. I will try to open the throttle, while stopped, to get the RPM's up, but it shuts off if it's still cold.
My questions are:
1. What am I doing wrong?
2. If I get to the stop light and the choke isn't engaged, I will try to rev the rpm's by opening the throttle a little, but it will instead shut off. Is this a potential problem?
3. Some of my friends say that I should let the bike warm up for at least 5 minutes, and other's say I shouldn't let it warm up more than a minute. Who is right?
Note: once the bike gets going pretty good there aren't any problems.
Thanks in advance for any help.
My questions are:
