I've always thought that the first start of the day or after a week or so, caused the most wear on the internal parts of the engine.
Years ago when I drove highly modified 62 FI Vette I installed what is known as an Accumulator. I purchased mine from Moroso performance company. The accumulator connects to the pressure side of an engine's oiling system. When the engine is running oil pressure forces reserve oil into the accumulator and compresses the air ahead. If oil pressure should suddenly drop due to hard acceleration or braking, air pressure immediately sends oil to the main galleries. When danger passes the pump is once again primed as oil pressure forces oil back into the Accumulator.
My concern was I wanted something to pre-oil the engine before making a cold start. This worked perfectly for that. Hit the switch just before firing the engine and the engine was brought to full oil pressure.
Wondering if anyone has thoughts about using this device. I don't think there is a reserve tank in the right size to fit on a motorcycle, but then I haven't checked for a while.
