OK Guys, I just got doing a top end rebuild and the engine started up after the 3 kick and sounded real good, but... when I tried to ride the bike, the clutch wouldn't engage.
The foot pedal seems to "Click" through the gears (I can hear at least 2 gears click), but the clutch handle is soft and the clutch won't engage. I replaced the clutch cable and it's attached to the rocker arm which seems correct, any idea what might be causing the clutch to no engage? Could it be the push rod? Do you think I need to open the clutch case and take it apart to diagnose?
Any help would be appreciated.
Jeff
Here is a picture of the clutch cable connecting to the rocker arm.
Jeff
