Hey I was adjusting my clutch cable and I did it by the book by loosening everything and then doing that turn on the adjustment screw with the locknut til it's lightly tight and backing off a half a turn ****. Ive done that like 20 times and seen that when I tighten it to much the clutch seems to pull the cable until it "pops" loose. Sounds like it's coming from the base of the cable (toward the engine) but I've opened everything up and couldn't see anything. Do you guys know why the hell my cable pops loose when I tighten it the way I want it? I feel like there's even more free play in the clutch lever then there should be but it still likes to pop loose. I believe my clutch plates are pretty worn though. Maybe that would explain why I can't tighten it up like I want it because when the lever is a smidge looser than I want it, it doesn't pop loose. What isn't being seated properly? Is something too worn? Plz help
