Alright gang, now for the next crazy edition of WTF is going on... Received the new stator yesterday.
Before installing the stator I bench tested it for fault ground, (all 3 leads back to the body of the stator) and ohms on all 3 leads to each other. Everything tested fine.
So installed it and same results as before but it gets weirder. Just like before at the secondary rectifier I get mid 13VDC if I put my meter to ground and slide the positive on the spade terminal between the rectifier and the output wire that runs to the battery like this:
At the battery still getting about .02 VDC over resting battery voltage with engine idling and revving it. Then I noticed the wires coming out of the R/R were RED HOT. Like melting soon hot. This never happened with the stator I replaced. I unplugged the stator and tested VAC and without revving it up, I was getting 30+VAC from each lead. Plugged it back into the R/R and unhooked the R/R from the harness and was getting anywhere from 13VDC to 22VDC. URGH! So the owner agreed to replacing the R/R, ordering that today. I just wish I was getting an over charging condition at the battery or off the secondary rectifier. Doesn't make sense the regulator is crapping out but still no charge getting to the battery. I would have expected some overcharging with 22VDC coming out of the regulator. R/R has a good ground.
This thing is testing me.....
