This question is about a scooter (DongFang DF300stg) but its more about a general charging question/confusion I’m dealing with. This bike is not showing any VDC getting to the battery from charging system. Normal battery voltage is all you get no matter the RPM. This thing has a 3 phase stator so when I checked the output I got the same readings from all 3 windings, was around 14VAC at idle and I could rev it up and get 30+VAC going into the Regulator. Now this is where it all went off the rails for me. Coming out of the Regulator I’m getting 13-14 VDC as I would expect. But the Red and Green wires coming out of the Regulator go into another small electronic component. When I looked the part up from the info on the label, it says it’s a Rectifier. It’s nowhere to be found on the parts list either. I’ll come back to that. (And it only has 3 wires, the Red and Green from the Regulator and one RED going to a fuse then to the + of the battery) So Red and Green wires carrying proper VDC are going into this Rectifier but no VDC are going to the battery. If I unplug the Red wire that is coming out of this component and hook my meter to the spade on the Rectifier, I get a steady 13.8 VDC. When I plug it back in and sneak my probe in there it drops back to battery voltage. So I left it unhooked, and used a jumper from the terminal to the + terminal on the battery and again just battery voltage. The jumper reads 13.8 VDC but the moment I touch it to the battery + it drops to whatever the battery voltage already is.
I am really confused what this Rectifier is in line on the charging system after the Regulator. As far as the Regulator, the parts list for this bike calls it just a Regulator, not a Regulator/Rectifier. But it’s obviously taking in VAC and putting out VDC so there is a Rectifier in it. I am unsure of why this other Rectifier is between the R/R and the battery unless it’s designed to smooth out the voltage which it seems to do.
Anybody familiar with a set up like this and have a clue why the VDC are doing what they are doing? Why the second Rectifier? The only complaint about the scooter was it recently started to fail to turn over occasionally but I had a hard time mimicking the issue. Finally got it to act like a dying battery 3 times after numerous starts.
REGULATOR
RECTIFIER
RECTIFIER
REGULATOR
RECTIFIER
RECTIFIER
