hi i have a 1980 Honda cm400t with around 21500 miles the bike was running great up until recently. lost the key so i put a switch on for the lights and power over a year ago. it runs around 10.5 volts when the lights are on but when the power switch is off it runs at 13 volts with the battery connected and when i disconnect the battery and turn off the power it will run around 20 volts at idle and 40 if i throttle up.
i have checked the stator, took it off and cleaned it. wasnt burnt. didnt see any bad connections and resealed the copper wires.
i check and replaced the fuses and connections.
replaced the battery.
is there anyway to test the regulator/rectifier?
any ideas what my problem could be?
