Hey so i recentlly posted a new topic with my throttle stop cable or my idle cable how it was totally off. So i took off my gas tank, and my air unit, and i finally found where that bad boy goes in so i put it in there, and put the air unit back on. And i started my bike and it ran great! This is with out the gas tank. Then eventually it bogged out and died, because there was no gas. So i was super excited. So i started putting the gas tank back on, and i was having trouble fitting on the Fuel regulator ( the thing were you can change it from On, Reserve, and off) I was having trouble getting that Thing fastened to the tank, so i took of the tubes going to the fuel reg. And then i put the fuel reg on the tank seperate, then i set down the tank and the already fastened fuel reg back on the bike, and hooked up the two overflow tubes to the tank, and the one small one going to the fuel reg. And then i realized that the big tube that leads to the fuel reg had a crack in it. So i cut it off at the crack, and now it is barely long enough to fit on the first half of the fuel reg. nipple. So i put all the tubes on. Screwed everything back up, put gas in it. No gas leak at all, Charged the battery. Then tried to start it.
Now it wont start! Everyonce in a while it tries to start and u can hear it trying to start out of the exaust but it just wont start! It sounds a little bogged down when it tries to start. But i have no clue what it is! Please help!!
Ps. Its a 94 cbr f2! and when i try to start it in first gear with the clutch pulled in, and the kick stand up, it starts to drive foward! >..
