I have a Honda 1980 CB125S that I picked up that was not running since the owner said it had not been run in years and the fuel tank/carb was varnished up. Problem I am having is that it only runs on choke. Or sometimes it will idle at No Choke, but as soon as you open the throttle a bit, it will die.
Things I have done...
- Checked compression. 120 with throttle closed, 150 with throttle way open
- Soaked/Cleaned carb.
- Removed and emptied gas tank, and flushed tank with gas.
- New spark plug and checked for spark.
- New battery, and have 6.35 volts on it at the moment.
- Checked for air leaks by spraying carb cleaner while running at the joints after carb....no effect. I even put some liquid gasket on the joints between carb and manifold, and manifold and case.
- Bought an after-market carb for like $25, but got same results.
- Put old carb back on, same results. Carb is a Keihin, PD 24A RH
I would appreciate any advice and help!!!
Thank you.
Thank you.
