Since the new gaskets and jets I have had no leaks I never fiddled with float height as my cv44 carbs are non adjustable, one recommendation if you have your right side cover the one that hides your air filter/intake box the reason I did all this work was a lean out at 5500 rpm about 60 mph she would fall flat on her face to shorten this up after all the carb work I could push 65 and that was it... Turns out the right side cover protects the intake from a vacuum generated by air passing over the air filter inlet I have get to locate a reasonable prices right side cover so I had to do some rigging and testing but now all is well
