I recently added a jet kit to my Shadow VT750DC. After putting it all back together I took it for a ride and now it seems like once it hits certain rpms it loses power until I let off the throttle and give it more gas. I took it apart and I inspected the floats. The only thing that I noticed was the one if the covers for the vacuum piston/chamber and a ding in the top of it. Once I put it back together it’s not as bad it’s more of sputtering in a way. Could this be affecting it or do you guys have any ideas? I’m not sure if it’s a vacuum leak or it could be something else. I posted a clip of it on YouTube to get an idea of it
https://youtu.be/eWkxq9XjcDM
With the work you did it's likely either a vacuum leak or the bike didn't like the jetting changes you made. What prompted you to do the jetting changes?
It was running lean because it has an open exhaust on it. They come from factory running already a little lean so it was causing a lot of backfire with the aftermarket open exhaust that was put on it by the previous owner.
Well I can't get to the YouTube but jet kits rarely work correctly when a person goes by the instructions only.
What brand of jet kit was it?
I only ask because some brands have you change some things seemingly just for the sake of change.
I like Factory Pro brand kits over most others because they are straight forward, no BS.
Anyway, the only (or best) way to dial in a jet kit is by reading the spark plugs.
As best that I can recall... those bikes used two spark plugs per cylinder.
At this point if I knew what year model the damn thing is I might be able to help... :plain:
Ya, not uncommon when jetting a bike to have to try a few different combinations. Did they send multiple jet choices with the kit? Plug readings, mileage tracking, and butt-dyno are usually what I go by. It takes a bit, but I can narrow down a combination I'm happy with within a few rides.
