I have a 1978 yamaha xs1100 and I cleaned my carbs and bench synced them and when i put it all back together it started right up but was running pretty rough. i tried to sync them with a home made manometer and im not sure what i did but i cant get my bike started. do i need to take the carbs off and bench sync them again or is there an easier way?
If all you did was remove the vacuum port screws and insert the adapters for the sync tool, I would say you introduced a vacuum leak. Go back through all the carb connections, and make sure that they are properly seated, and the fuel levels are good.
yeah I agree with winter...
vac leak somewhere,
or you synched them with a bad vac hose....during synch.
