My bike fell over while pretty much not moving. I was pulling in to park, something happened and I had this feeling like I could tell it was going to fall soon. The driveway had a little bit of an angle and I was moving really slow already. I was able to kind of slowly set it down without any noticeable body damage.
Riding to work this morning I notice shifter peg is bent when trying to downshift. I pretty much could not shift down, I managed to and then pulled over. Pulled it on the end by hand and managed to drive to work with it feeling pretty smooth.
It's still slightly touching the rubber coated whatever it is when you shift. Wondering if I can bend this back slightly while it's attached? Do I need to remove it first? It only needs to move the slightest little bit.
About the light issue, it was not on before the fall and now it comes on when I turn the key and goes off when I crank it up. It does not show up at all while riding and the bike seems to still run great.
The bike is a 2015 Suzuki GW250 with 4k miles. Any help would be amazing. Thanks
