1982 Honda CB900C
I have a leak between the front brake fluid reservoir and the master cylinder. It started after I had the front calipers worked on by the local Honda dealer. They made a real mess of the bike, I won't get into it but I won't go back there.
I replaced the o-ring between the reservoir and master cylinder. It only leaks when I ride it. No leaks when it sits or when I squeeze the brake lever. I suspect that when the fluid heats up it expands and causes the leak at the o-ring. The small ports in the reservoir cover look clear.
I'm stumped.
Pete
An oring can leak if overtightened and smashed flat. The only other thing I can think of is damage to the mating surfaces.
Thanks Dodsfall. I believe you're right about the mating surfaces. I took a good look at the groove in the master cylinder. It has quite a few scratches in it. The groove is tiny, as you know, and I'm trying to figure out a way to somehow polish it. I'd hate to have to buy a new master cylinder just because of this.
Master cylinder
You can split a chop stick and insert a fine piece of sand paper. Some guys turn it with a drill, but by hand seems to be less dangerous. I will be doing this soon on my 80 XS1100.
That o ring under the reservoir usually does not leak, but the top cap can. Both will require a careful study. Too much fluid could also cause a problem. Mind you, I seem to do that often.
The reservoir itself may have been misshaped or damaged.
Unkle Crusty*
