I have been trying to figure out how to make an electric Velomobile into a legal Moped or Motorcycle.
For a moped in the state of Washington you can't have more than “2 brake horsepower” at the axle. Can anyone tell me how to do that? If it is just the HP of the motor before the gear losses, I could just limit the wattage input with the controller. But that would make it climb hills much slower. It takes 2500 watts to climb our steep hills at a reasonable speed.
Maybe it has to be a lighter vehicle, like 400lbs total combined weight.
What are the Magura BIG hydraulic disc brakes rated for? Assuming dry weather and proper adjustments.
I like the idea of making it a moped, limited to 30mph, because it would not have to be built so heavy? Mileage is the prime reason for the whole project.
I know someone that built one that could handle at least two adults and maybe 80lbs of cargo as well, but they did nothing about making it legal. Rather a difficult project at 600lbs.
I have a motor picked out: a 1.6hp series wound DC motor. I do not like Hub motors.
The motor looks like it could produce more than 2 horse power (I can limit that with the controller), and way too much speed. So I calculated that if I use the right size rim pulley on the drive wheel it will not only have enough torque to climb our steep hills but keep the speed down to a legal limit.
