1 - 7 of 7 Posts
Hi people im here in New Zealand I have recently purchased a 1983 BMW RS1000 it has a problem with one of the cylinders smoking on start up the guy i bought it from described that there is oil under the carburettor can anyone assist me with this once the bike warms up it dissapears
Discussion Starter · #6 ·
It was parked on centre stand for the past few days still smoked when i fired it up but thanks i will keep it on the centre stand as suggested
There is the possibility that the rings are leaking, but it was a common issue with using the side stand. With the piston being in a lower position, some oil can still make it past the rings even if they are reasonably tight.
You can do a compression test to be sure they are still sealing to spec.
1 - 7 of 7 Posts
