78 suzuki gs 550....keep blowing main fuse about a block from home. Can let it run for 10 minutes in garage , but assign as I start driving it will blow..not sure if there are different types of 15 A' s..did notice that a green and white and blue and white connection have gotten very hot and kinda blocked the plastic insulation around it..these could go to generator...thoughts will help e sleep at night
On The Road Again!
Might be when you hit the brakes that the brake light is blowing the fuse.
It can sit and run in the garage because you aren't using the brakes.
Just figured that out..tks for that observation...tomorrow will check out the wires..thanks again..be safe
