1 - 12 of 12 Posts
Hello, I bought my Hyosung GT250-R a week ago and while I was at the lights I stalled the bike today and it was not starting. After several tries, the bike started and I went on with my journey. I parked the bike for around 10mins and later came to find that the bike was not starting. I turned the ignition on, kill switch on, kickstand up, clutch in, turned it on and no sound. I tried this in first gear and in Neutral but nothing. I had to roll the bike down the hill and start it with the clutch meathod I found on youtube. Anyone know if this is a battery issue or another issue. Any help is greatly appreciated. Cheers!
Does is click, or make any sounds? Do the lights turn on when the ignition switch is on? The first thing to check is the battery connection. Make sure both the terminals are tight, and corrosion free. You can also pick up a cheap volt meter if you don't have one and check the battery voltage
Sent from my Pixel 3a using Tapatalk
Hi, thanks for the comment. The bike does not click, and yes the lights and the dash light up when the ignition is on. The battery connections are firm and I will be checking the battery volts in about 30 mins and get back to you with how it goes. Thanks
Sounds like a super dead battery. If the battery was kind of dead, it would make clicking sounds when you went to start it. If there's no clicking, then it sounds like a completely dead battery. Time to replace it. They are not expensive though.
Sent from my LM-G710VM using Tapatalk
Discussion Starter · #5 ·
But all the lights come on and the dash lights up aswell.
Discussion Starter · #6 ·
Could also be a bad kickstand switch, or kill switch. If the batter voltage is good, you probably need to do some checking on the switches... maybe the starter connection too.
12.25 is a half FLAT battery. Turning the key on is kind of like a load test. It failed that too.
Buy a new battery. Read the instructions. Get a battery tender. A day later after the battery has been sitting a while, check the volts, if around 12.75 bung it in, fire up the bike, and check the volts again. Should be 13.25 to 13.5 at slow revs, and 14 to 14.5 at higher revs. If it is charging, go for a ride.
UK
Of at least 20 miles. The more the better. Takes about that long to burn off any moisture and to recharge the battery from starting. If you can't ride for at least 20 miles or around 20 minutes, why ride at all.
1 - 12 of 12 Posts
