Battery Chemistry Lesson
As a battery discharges, the surface of the lead oxide plates is reduced to lead sulfate as they release electrons.. The sulfuric acid in the electrolyte combines with the lead, releasing the oxide (oxygen). The electrolyte becomes more and more water and less and less sulfuric acid. The specific gravity of the electrolyte goes up or down, I can't remember which.
H2S04 + Pb02 --> PbS04 + H20 + e- (discharge)
PbsS04 + H20 + e- ---> Pb02 + H2S04 (charge)
Charging is just the opposite, by supplying an electron the Lead Sulfate is OXIDIZED (rusted!) to Lead Dioxide (Pb02) releasing a sulfate molecule which combines with the hydrogen and becomes sulfuric acid.
(It's fair to note that it's not a 100% efficient reaction, SOME hydrogen and oxygen "bubbles or boils, trouble and toils" its way out of solution which is why batteries have to be vented...and can sometimes explode --- while charging.)
It's also worth noting that if you put 100 Amp-hours into charging a lead-acid battery, on a GOOD DAY you might get 20 usable Amp-hours back OUT of same battery, which is why storing power in batteries is a losing game. (Why? because a battery has internal resistance, and MANY of those "lost" 80 Amp-hours simply went to warming up the battery, it's case, electrolyte, plates, surrounding environment.... just like a toaster, a batterh acts like a resistance heater as well as an energy storage device)
So you take a brand new battery, with lead / lead oxide plates which have never even tasted sulfur, and all the sulfuric acid is in the electrolyte you just poured into it, it's "born" 100% charged.
Oh sure, you can top it up with a charger, and battery mfr's often suggest that, but if it's already 12.6 or above...you're not accomplishing much. Just putting a "surface charge" on an already charged battery.
Mind you a battery manufacturer COULD ship you a brand new battery with already sulfated plates, you'd fill it up with distilled WATER, and THEN charge it rather than shipping caustic sulfuric acid....
What's MORE interesting to me, in the area of "self charging" is if you leave your lights on and come back to a flat battery, if you turn everything off and leave it all alone for 10-30 minutes you'll OFTEN regain enough charge to crank the motor -- once!
