The ECM receives information from the throttle and several engine sensors and, based on its map, commands (energizes) the fuel injectors as to when to start and how long to spray (pulse width) fuel into the intake tract, while the throttle body butterfly regulates the air supply.
http://www.dallashd.com/--articles-supertuner
http://www.beartoothonline.com/bthd...bid/637/Article/20/Screamin-Eagle-Tuners.aspx
>H-D's Electronic Control Module (ECM) is located either under the seat or behind the chassis side panel. Look-up tables, also known as [fuel and ignition] maps, are stored in the ECM for a specific engine and are used to provide the correct amount of fuel [to be injected] under various engine settings, [operating conditions, such as idle, wide-open throttle, and cruise conditions] temperature, and weather conditions. If the engine is upgraded with [less restrictive] exhaust, [wilder, greater valve overlap] cam, head porting, [increased] displacement, or other modifications, the map must be updated for the new parts combination.
http://www.hotbikeweb.com/harley-davidson-electronic-fuel-injection-tuning-aids
>Electronic fuel injection [EFI] reduces [vehicles] emissions because it meters fuel more accurately than a carburetor. It also offers riders the benefits of improved cold or hot starting, crisper acceleration under varied operating conditions and smoother running at high altitudes.
http://www.hdforums.com/forum/ignition-tuner-ecm-fuel-injection-55/
A real WEALTH of information on tuning on THAT site...
>ThunderMax is a... performance engine management system for EFI equipped Harley Davidson models. The ThunderMax ECM replaces the stock module and helps “unlock” various performance advantages not possible by “Flash” systems and other post-[ECM]“piggy-back” tuning devices.
ThunderMax’s key performance advantage relies upon its proprietary AutoTune technology which utilizes 18mm Bosch wide-band oxygen sensor feedback to provide continuous AFR tuning corrections based upon [actual] riding conditions like temperature and altitude.
http://www.thunder-max.com/
And the book I'm currently reading:
[ame]http://www.amazon.com/Motorcycle-Management-Systems-Motorbooks-Workshop/dp/0760340730[/ame]
