07 ninja 650r
about a month ago I tore the bike down to just frame and left the engine in. Kind of a pre summer inspection... ok maybe a little more then an "inspection" lol
Replaced quite a few little parts (bolts, nuts, springs etc) and I did have to replace throttle body with used one from ebay. I stripped my buttery valves on the old one.
I completed the rebuild just a little bit ago. I let the fuel pump prime about 4 times before starting. Fired right up for a second, fired it again and she sang beautifully. I only let it run for a min because I was trying to let new fluids cycle and top them off and 3 weeks worth of PB blaster was burning off the exhaust header.
After shutting it off and fuel cap closed, massive amount of air came gushing past the cap seal. I opened it up real quick to help it exhaust out (it was alot). I let the tank breath for a min, it has been sitting in the corner of my hot garage for a couple weeks so I figured vapors finally found a way out.
Came back a few mins later and closed the cap, raised bike off kickstand to push into garage and instantly started gushing again.
Would I be correct in assuming it's just trapped vapor build up? Or maybe something to do with the used throttle body I should look at?
I'm 99% sure all electrical and vacuum lines are hooked up correctly because I labeled every single line with blue tape and only removed the tape after they were plugged in.
NON Cali model
Aftermarket exhaust
Snorkel delete
PAIR valve bypass
NON Cali model
Aftermarket exhaust
Snorkel delete
PAIR valve bypass
