Suzuki Gs250 t 1980
Why would our air cleaner assembly be collecting gas in it .. outlet on driver side :biggrin: .. is leaking out gas after a run and continues ..
Actually, you can try tapping on the side of the bowl with a brass drift or wood block to see if you can nudge the float loose, if it's the float that's sticking. Other then that the best way is to just open it up and find out what the problem is and address that.
Yeup ..that seems to have shut off the overflow ..:)
Thanks
Bob
