As the title suggests, I have no spark. I do not have the Suzuki tester for the ignitor as they request. I have no power going to either coil, which I suspect is part of the problem. I also do not have any power coming in to the ignitor, and I don't know if there should be, but I assume so. I disconnected the wires going in to the ignitor and tested for voltage and didn't see any. The fuse at the relay is good. Wondering if anyone knows where I should start. What wire carries the power to the ignitor? Wiring diagram is rather confusing to follow and doesn't necessarily tell me which wire carries voltage in to the ignitor.
I'll be the one to ask a dumb question. Is the battery at 12.5 volts or around that much and are your ground connectors clean and tight? I assume you've check that but I had to ask.
