I have a 1986 yamaha radian 600. I pulled the motor and put it in a dune buggy. I got it wired back up and it starts and runs but... as soon as I put it in gear it dies.
What I know:
I bypassed the kickstand switch (cut wires and tied them together). The motor won't even turn over without these wires tied together.
I bypassed the clutch switch. The motor will turn over, run and stay running no matter how I have these wires, (tied together or not).
I found what I believe is the neutral switch( wire coming from the motor right by the sprocket), the motor will start and run only when this single wire is plugged into the harness.
Nothing dealing with lights, speedo, tach, horn are hooked up, just unplugged from the harness.
Does the switch on the brake lever/pedal have anything to do with this?
I appreciate any input. Thanks
What I know:
