1 - 12 of 12 Posts
Hi all...I need to remove both tanks on this 85 VT 1100 to flush the fuel system...Found a free Haynes manual download...real crap...couldn't find a word about removing the tanks or carbs...Any info will be a help...Thanks
The V Twin is the VT and the V4 is the VF...I have the VT ( V Twin ) shadow...wasn't the V4 the Magna...? Thanks
Not in the budget...I booked marked it though...just in case the old lady will kick the budget up a few bucks...I was looking
for a free download...Thanks a lot ! ! !
See if you can find a Hondo specific site for your bike. Usually you can find a download there.
Discussion Starter #8 (Edited)
couldn't find one....still looking...I did however flush both tanks and cleaned the carbs...she is running like a brand new toy...with 33xxx+ miles on her...I
do need some help finding a cheap battery with good ( 260 + ) Cold Cranking Amps (CCA)...the 85 VT 1100c had that strange T shape battery...I'll post a few picture once I get the oxidation off the wheels and engine...Its a mess...I'm 67 yrs old...easy way to get those wheels and engine clean would be a big help...I'm all ears people...I hate that part of saving these old V-Twins
from the salvage parts yard...the sanding and cleaning...Thanks and be safe out there people...Later
V4's the Sabres too! Ox depending on the pitting! Some use marvel oil, some go straight to sand paperwith some type of lube& re spray clear coat! Mine was Farley good shape so I just removed the coating & buff to high gloss with mother's & applied a up date when cleaning the bike! You can also use scotch brite pads or disc!
1 - 12 of 12 Posts
