Did you buy brand-new OEM factory carbs from authorized dealer? If not, they're used and just as clogged and dirty as your originals.
Any of above if not done will cause you running issues. Carb's aren't "easy", send them to pros with decades of experience customcarbservices.com, Professional motorcycle carb cleaning . Guaranteed to have your bike running like brand-new off showroom floor!
Also how is fuel-pump wired? Driven by proper fuel-pump relay? Or just generic on/off relay or worse, on/off switch? Fuel-pump relay is pulsed by ignitor, which then pulses pump. So pump DOES NOT RUN until engine is spinning!!! The faster engine spins, the more ignition pulses per second and more fuel-pump relay pulses to pump which flows more fuel. This allows pump to vary its output to tiny bit at idle/low-RPMs and increase volume at higher RPMs where extra petrol is needed.
Sounds like you've got both carb AND fuel-pump wiring issues.
- Did you completely disassemble carbs down to every last single nut, bolt & individual component? If it can be further taken apart, do it.
- Scrub out secret hidden passages in carb-body with PEA-based fuel-system cleaner and scrub brushes?
- Did you ultrasonic soak everything?
- Poke out all bleed holes in jets, emulsion-tube, carb-venturi with matching gauge soft copper wire?
- Micro soda-blast everything before re-assembling?
- Replace all rubbers: float-valves, pilot-screw O-rings, fuel-rail O-rings, float-bowl seals, even slide-diaphragms if needed
- Set float-height with final wet-test to confirm
- Sync carbs with manometers.
