1 - 1 of 1 Posts
I have an 1984 Honda Sabre and have been having some problems with the hydraulic clutch.
The clutch was slipping, so I replaced the clutch spring which was broken. And now the clutch will not operate correctly. The clutch doesn't want to release.
I've read the manual, and it says that when you have the clutch disassembled you are not suppose to disengage it. However, before I read that little bit in the manual I had done exactly that - disengaged it while the clutch was disassembled.
Could this be the cause of the problem?
If anyone has ideas or suggestions on where to look, I would greatly appreciate it.
1 - 1 of 1 Posts
