still can't get starter button to work. power to button and kill switch...another question is there a positive side to starter relay...can turn it over my crossing the post on relay...have checked all grounds and battery is new
Check the solenoid itself... Take it off (after removing the battery negative) and bench test it. Apply 12v to the primary (small side) while testing ohms on the big side. When you put 12v to it, the big side should switch from infinite to zero resistance.
will do that.the relay i got are both the same size...more will be reviled....thanks
i did the bench test... has a battery on bench for testing..put 12 to small side and need got the ohms to go to 0..but did put green yellow to a power supply and it did click ...obth new and old did that...
