1 - 2 of 2 Posts
Hey! I have a 1975 honda cb200t with a broken front end (due to an accident). My friend is willing to give me the front end of an 81 Honda cm400t. I want to know if the cm400 front end will fit into the cb200t?
I know they differ in sizes, for example, the diameter of the forks are 33mm (cm400t) and 31mm (cb200). I know there are a bunch of differences but I cant find any information if they would be compatible! Can I do this? pls help :)
The 2mm difference in the fork tubes is leaning to the no side. Then there could be a length issue. Not to mention you would have to change the triple tree, and the 200 probably will not fit. The rake angle might also be different. But here is an idea. Get a set of forks from another 81 cm400.
UK
1 - 2 of 2 Posts
