Hi, I'm out of Cincinnati,OH. Just got my first bike last week. 1981 Suzuki gs550l.
Got it off of Craigslist and one of the many issues is the starter. It will crank the engine all day long but will not turn it over, not even a sputter but I can bump start it and all. I was wondering if there was an issue with the carbs or the electrics. It's does not have the airbox or pods on it.
Thanks in advance!
I had a brand new battery in there when I was cranking it. When I said "I could crank it all day" I meant it as if I was trying to start it to ride it. It acts as if there is no gas getting to it. (the pet **** was on and there is fuel in the tank)
I've pulled the plugs and all four have compression and spark when using the electric starter.
The stator works fine. The battery is at 13.9 when it's running and 12.9 (or something around there) when I turn it off.
I'm going to get it out today and I'll attach a video in a comment later to help out. Sorry for any confusion.
Let's get something clear. Your first post says you can bump
START it. But your last post says it may not be getting fuel. So, does it ever start or not?
I suspect the answer is it does not but you are sure confusing the heck out of things. I'll assume it does not start. So do you know how many years it's been since it last ran? I'll assume the answer is you have no idea. Did you drain the tank and put fresh fuel in?
Pull the plugs after you have cranked on it. Are they wet or dry? If dry then you'll have to dig into why. Is the fuel shut off really on? Does it have a prime position?
Accurate details of what is happening and what you've done would sure help here. If everything is indeed correct and there are no leaking boots then you'll probably need to work on the carbs.
It's beginning to sound like you'll need to go through the whole fuel system though. That's about it for me. Good luck.
