on the 5 speed trans, first you must make sure the shift cam plate is engaged in the notch between 2nd and 3rd. the spring loaded plunger is on the bottom of the case. install the outer cover with the middle tooth of the ratchet alined with the mainshaft, then ck yer shifting, let me know if you need more help
