@ Benny - you've mistaken the imperial gallon for the US gallon.
US gallon is 3.79 liters
yes i'm sure we've had this discussion before.....
your inches are smaller too - so when you say you have an 8" ****, it's actually only 5
pretty sure that here, you can only tow a trailer if you have a reverse gear, so afaik the only bike you can use is a leadwing
* just to prove i am not always right....
UK Motorbike Towing Law
A motorcycle/sidecar combination is treated as a solo motorcycle. A trike unit is legally treated as a 3 wheeled motorcycle (a motorcycle/sidecar combination is not!). A trike can tow up to a maximum gross weight of 254kg.
Legally for a solo motorcycle to tow it must have an engine capacity over 125cc.
The trailer must not exceed 1 metre in width.
The distance from the rear wheel spindle to the back of the trailer must not exceed 2.5 metres.
The Motorcycle must be marked with itโs kerbside weight.
The trailer must be marked with its unladen weight.
Maximum towed weight, including the trailer and itโs load must not exceed 150 Kg. (330 lb.) or two thirds of the motorcycles unladen weight, whichever is least.
The UK speed limit is 60 mph on dual carriageways and motorways.
Lighting regulations are the same as other small trailers.
You cannot tow more than one trailer and passengers are not allowed to be carried inside the trailer.
Legal requirements vary from country to country and in some European countries it is illegal to tow with a motorbike. In those counties where it is illegal towing is permitted to visiting UK citizens during their stay. We would recommend you check with the relevant authorities before travelling just to be sure.
