I have a 2008 suzuki boulevard m50 with cobra streetrod exhaust, k&n air and oil filter, and dynojet power commander v. The issue I'm having is that it is running to lean. It also is popping a lot. Does anyone have a fuel/air map that would fix this issue. I don't want to have to pay $300+ to get it tuned on a dyno
2005 Suzuki C90T
I would contatct the mfg. i would have also went with a GMan. They work right out of the box.
MODERATOR
Check for an air/ vacuum leak.
Sam:)
Also check for an exhaust leak, as that will cause popping as well.
