1 - 12 of 12 Posts
· Registered
before it sounded this bad, my motor made a little whine at idle nothing bad or not normal but I went riding the other day and I noticed a lot more whine and something was definitely not okay. the whining got way louder and one of my mechanic friends says it sounds like a bearing. I checked my dipstick and there was not a drop of oil on it. The sound is coming from the bottom end more on the clutch side.
· Visionary
Did you fill the oil up?
· Registered
Discussion Starter · #4 ·
Yeah honestly I think it was a coincidence that I checked the oil level when I heard the whine because I’m starting to think it’s the crankshaft whine recall. Having the exact same symptoms and I did start doing a lot of clutch ups before it started happening which makes the whine start
· Registered
Wheelies + low oil = spun bearing. Not always, but often enough...
  • Sad
Reactions: mike721
· Registered
my bike is showing no symptoms of a spun bearing. No loss of power, engine lights, just the whine.
Admittedly, my experience is very limited but the bike I had that was in that condition still pulled strong and had no engine lights showing. My only clue was a light knocking after it had warmed up.
Hope it's any easy fix for you!
· Visionary
Quite a coincidence, you run a bike with very low oil, doing wheelies which will cause gravity to move what oil you have away from the pump pickup and starve the engine, while the engine is being asked to perform at a high power level and then it starts suddenly making bad noises.
Seems like a pretty decent argument for the low oil being the cause of engine damage which is causing the whine.
So why not take it to your dealer and let them do the recall before you cause them to void the warranty for yet more reasons?
Because the warranty is long past the valid time to have it done for free and actually be under warranty.
But a recall has nothing to do with the warranty. Since it’s past warranty anyway, it seems logical to let them do the recall and you pay for any extra parts needed. You might have had a recalled bad bearing is my thought, even though you didn’t help it with low or no oil.
1 - 12 of 12 Posts
